I made the change from 1.3 to dynamo 2.1… got most scripts working again, but my script with
viewport.setboxcenter is not doing what it needs to do anymore…
Some further investigation, this is the script inside the node;
#python nodes in dynamo 1.2
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
vport = []
for i in IN[0]:
vport.append(UnwrapElement(i))
pts=[]
for i in IN[1]:
pts.append(UnwrapElement(i).ToXyz())
# Start Transaction
for v,p in zip(vport,pts):
v.SetBoxCenter(p)
doc.Regenerate()
# End Transaction
OUT=IN[0]
this is the error i am getting;
File “”, line 35, in
AttributeError: ‘Viewport’ object has no attribute ‘ToXyz’;
Try switch the inputs, viewports to “Points”, your points to “Viewport List”. Also, I guess the output from your previous node are already XYZ, the last node expects Dynamo Point object and it convert them to XYZ object but I suppose there’s not much influence if XYZ gets converted to XYZ one more time.
tried the switch already…doesn’t work
in the node itself it is the other way around… the 0 and 1 input caught my eye as well already
also tried to remove the ToXyz, doesn’t work either
error i am getting then is;
expected an indented block
vport = []
for i in IN[0]:
pts=[]
for i in IN[1]:
Try indent then.
that is the original code right… or am i missing something… original code gave an error
Strange
, can’t find any other reasons.
