I am trying to figure out why I am getting different results when using viewport.locationdata node in two scenarios:
1st scenario:
Having a floor plan view open, I am creating viewports and they are being placed on a sheet using Viewport.Create. Then I use the node Viewport.Locationdata and get the following results:
2nd scenario:
In this scenario, I have already created the viewport using the same node but I have the sheet open(A7.1)and then I run the viewport.locationdata. For some reason, I get different results.
As you can see, the node is giving me different results, even though the viewports are in the same location on the sheet. Both the view and the sheet have the same origin.
Any ideas why is this happening?
