I’m using the Element.GetLocation node to find where my Titleblock is on the Sheet (in case it got moved from 0,0)
My problem is that after I use it, I get a Dynamo point (little blue square) added to a Viewport on the Sheet, which then messes up the coordinates of the ViewPort.
Here’s my Viewport before I run my graph:
and here it is after:
That “After” image shows three Dynamo Points.
One is from the OOTB Element.GetLocation,
one is from SteamNodes View.ViewportBoxCenter and
one is from the Archi-lab Viewport Properties node
I’ve tried Freezing them one by one, and I’m certain each of those nodes places a Dynamo Point.
Those Nodes should all be read-only, so I don’t understand why my Viewport is changing.
Is there a way to prevent those points from being added?
Super-frustrating, since the only way I know to clear them is to close the Revit file and re-open a fresh copy.
