I’m making a graph designed to create sheets by plan views.
The first step is to collect the plan views (then filter them by some project parameter). That’s where I use the View Type node.
The problem: Whenever I shut down the graph file and then re-open or re-run it, an additional View Type output port appears on the node. The connector jumps down to bottom output and the node gives an error message.
So each use, I have to delete the node, recreate it, and reconnect it in order for the script to work.
Unfortunately, It’s not the first time I see this happening with nodes. Am I the only one?
I’m using dynamo 2.0.1 with Revit 2019.1
