View Templates Collector
Is there any View Template collector that I can use in my skript?
I’m generating apartment typology using area plans, but I need to set the view template myself, I want to use Data Shape to select areas and so. I want to have the possibility to set the view template from UI
Here an easy solution to collect all the view Templates:
Otherwise, archilab has really interesting nodes that allow you to choose the view template exactly as the normal revit node do for the Views, using a scrolling menu’
Thank you @Giuseppe_Dotto
