I tried to transfer view templates from a Revit link to the current open Revit file to apply it on floor plan views of Revit Spaces, and what I notice is that the color scheme defined in the template is applied but the filters do not exist because it seems I need:
- the shared project parameter that does the filter, added in the current project parameters list.
- Activate linked documents in the color scheme, because I want to visualise only links in the current revit file.
So the problem is when I add that shared parameter I can use it but the definition of the fill solid color and hatches are random and I have to edit all of them manually comparing between the revit link, so it is a hard work and I would like to know if Dynamo can help to reuse identical color schemes of view templates.
Here a sample of the issues
