So the OTB node ParameterFilterElement.By Rules doesn’t work with the parameter “Family and Type” or
“Type” when working with Callout, Elevation and Sections category? It seems to only work with a few fields.
Solved…
You have to pull the parameter from views as parameter id, because its just like when a room is room number + room name (duh). The view lists - of course, why not - has three parameters all called “Family and Type”.
But if you pull “Family and Type” off using the defaults node, you’ll get parameter -1002025. When you really want -1012106
