Hello, I’m trying to re-work a script that somebody else created and is currently not working. I have attached the problematic problem of the graph and pasted the python script below. It is supposed to (and does) create .png slices through the height of the model. What it is not doing, however, is giving me any output in dynamo—which I am expecting. Can somebody please look at the end of the python script and give me advice as to why the outputs are not working? This worked years ago, so I wonder if it has to do with dynamo and/or python being updated and a command not working anytmore.
Thanks so much. I’m familiar with Dynamo but have a hard time with Python at the moment, though I’m actively learning.
# Import Element wrapper extension methods
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import FilteredElementCollector as _FilteredElementCollector
from Autodesk.Revit.DB import ViewFamilyType as _ViewFamilyType
import System
from System import Array
import sys
sys.path.append("C:\Program Files (x86)\IronPython 2.7\Lib")
import os
import math
import shutil
def clean_up(folder_name):
for file_name in os.listdir(folder_name): # delete all content
file_path = os.path.join(folder_name, file_name)
if os.path.isfile(file_path):
os.remove(file_path)
shutil.rmtree(file_path)
os.makedirs(os.path.join(folder_name, "origin")) # add origin folder
def get_ViewFamilyTypeId(viewFamilyTypeName):
names = []
ids = []
viewFamilyTypeId = -1
collector = _FilteredElementCollector(doc).OfClass(_ViewFamilyType) #collecting all elements of type ViewFamilyType
for t in collector:
names.append(t.FamilyName)
ids.append(t.Id)
if t.FamilyName == viewFamilyTypeName:
viewFamilyTypeId = t.Id
break # get the first
return viewFamilyTypeId
def create_view(doc, viewFamilyTypeId, boundingBox, voxel_size):
if viewFamilyTypeId != -1:
boundingBoxSlice = boundingBox
boundingBoxSlice.Max = XYZ(boundingBox.Max.X, boundingBox.Max.Y, boundingBox.Min.Z + voxel_size) # adjust boundingbox for far clip offset
sectionView = ViewSection.CreateDetail(doc, viewFamilyTypeId, boundingBoxSlice)
viewId = Autodesk.Revit.DB.ElementId(int(str(sectionView.Id)) - 1)
minY = boundingBoxSlice.Min.Y
maxY = boundingBoxSlice.Max.Y
midY = (maxY + minY) / 2
minX = boundingBoxSlice.Min.X
maxX = boundingBoxSlice.Max.X
minZ = boundingBoxSlice.Min.Z
axis = Line.CreateBound(XYZ(minX, midY, minZ), XYZ(maxX, midY, minZ)) # flip DetailView direction
ElementTransformUtils.RotateElement(doc, viewId, axis, math.pi)
return sectionView
def update_view(doc, view, voxel_size):
translationVec = XYZ(0, 0, voxel_size)
viewId = Autodesk.Revit.DB.ElementId(int(str(view.Id)) - 1)
ElementTransformUtils.MoveElement(doc, viewId, translationVec)
return sectionView, height
def export_view_image(view, path, image_width, doc):
ieo = ImageExportOptions()
ieo.ExportRange = ExportRange.SetOfViews
ieo.SetViewsAndSheets([view.Id])
ieo.FilePath = path
ieo.PixelSize = image_width
doc.ExportImage(ieo)
return ieo.IsValidFileName(path)
def delete_views(doc, views):
for view in views:
doc.Delete(view.Id)
def apply_viewTemplate(doc, view, viewTemplateName):
viewTemplate = None
collector = FilteredElementCollector(doc).OfClass(View)
for i in collector:
if i.IsTemplate == True and i.Name == viewTemplateName:
viewTemplate = i
if viewTemplate is not None:
view.ViewTemplateId = viewTemplate.Id
def get_scopeBox(name):
elements = collector.OfCategory(BuiltInCategory.OST_VolumeOfInterest).ToElements()
for element in elements:
if element.Name == name:
return element
def rename_images(digit, folder_name):
path = os.path.join(folder_name, "origin")
new_filenames = []
for f_name in os.listdir(path):
new_f_name = f_name[0:digit] +'.png' # 3 digits worth
os.rename(os.path.join(path, f_name), os.path.join(path, new_f_name))
new_filenames.append(new_f_name)
filePath = IN[0]
slices = IN[1] * 12
scopeBox_name = IN[2]
viewTemplateName = IN[3]
is_delete = IN[4]
clean_up(filePath)
scopeBox = get_scopeBox(scopeBox_name)
filenames = []
try:
count = 1
heights = []
viewFamilyTypeId = get_ViewFamilyTypeId("Detail View")
boundingBox = scopeBox.get_BoundingBox(None) # https://github.com/DynamoDS/DynamoRevit/blob/Revit2015/src/Libraries/RevitNodes/Elements/Element.cs
voxel_size = (boundingBox.Max.Z - boundingBox.Min.Z) / slices * 12 # feet to inch
image_width = (boundingBox.Max.X - boundingBox.Min.X) / voxel_size
if image_width <= 15000:
bottom = boundingBox.Min.Z
top = boundingBox.Max.Z
height = bottom
digit = len(str(int((top - bottom) / voxel_size)))
sectionView = create_view(doc, viewFamilyTypeId, boundingBox, voxel_size)
apply_viewTemplate(doc, sectionView, viewTemplateName)
while height < top:
# if count > 10: # TEMP for test
#break
heights.append(height)
height += voxel_size
update_view(doc, sectionView, voxel_size)
imageName = filePath + "\\origin\\" + str(count).rjust(digit, '0') # filename format: "tempFileName - view type - view name"; craete origin folder
isValid = export_view_image(sectionView, imageName, image_width, doc)
filenames.append(imageName)
filenames.append(isValid)
count += 1
if is_delete:
delete_views(doc, [sectionView])
TransactionManager.Instance.ForceCloseTransaction() # Dynamo transaction force close order
rename_images(digit, filePath)
OUT = "success", digit, sectionView, image_width, str(voxel_size * 12) + " in" # other outputs: boundingBox.Min, boundingBox.Max, heights
OUT = "failed: image_width out of range > 15000, please set larger # of slices", image_width
except Exception as e:
OUT = "failed", e
test dynamo script.dyn (16.6 KB)
