Just downloaded Vasari 3 Beta a couple days ago. But I haven't been able to use the product because it won't activate. It keeps showing a processing error. Please help. Thanks
Thanks so much!
I ended up uninstalling AND deleting the install files (Located at c:Autodesk for me). Then re-downloading the whole thing again and it worked.
Hi, I have found the same problem. I uninstalled Vasari and re-installed the program entering the correct serial number. When the program starts up, it displays exactly the same message as above posted. Please assist, thank you
No, sorry. If you try the Install now, it should enter the serial number automatically.
Okay thanks, Is it possible to change the serial without reinstalling?
The correct serial number (as of 9/26/13) is
385-63879928
