Is it possible to pass a property as a variable?
vt = [i.by for i in collectedViewTemplate]
def listOfViewTemplates(by):
collectedViewPlans = FilteredElementCollector(doc).OfClass(ViewPlan).ToElements()
collectedViewTemplate = [i for i in collectedViewPlans if i.IsTemplate]
return vt
OUT = listOfViewTemplates(Id)
NameError: name ‘Id’ is not defined
I can think of a way, but it will change some of your code.
Instead of accessing parameter values by i.by, use i.LookupParameter(paramName).AsDouble() or .AsString depending on the storage data type.
https://www.revitapidocs.com/2015/4400b9f8-3787-0947-5113-2522ff5e5de2.htm
@aclarke What about something like that?
@salvatoredragotta
Awesome Sauce, thanks Sal…
I don’t 100% understand what the exec() function is doing, could you give me a quick breakdown of what it is doing in this code?
def listOfViewTemplates(by="Object"):
collectedViewTemplates = [i for i in collectedViewPlans if i.IsTemplate]
if by == "Object":
vt = [i for i in collectedViewTemplates]
try:
exec("vt = [i.%s for i in collectedViewTemplates]" %by)
except:
vt = "No Property by this name exists"
return vt
OUT = listOfViewTemplates(), listOfViewTemplates("Id"), listOfViewTemplates("Name")
Thanks Sal, I did look up exec() before asking, it was the %s & %by that id did not understand, which I learned is formatting the string, allowing the property to be passed as a string, and exec() runs the string as code. Pretty slick
