Hello!
How to get “As value string” parameter (in my case reinforcement Volume)? And what the patterns between Value and “As value string” in Revit? How it’s calculates?
Hello!
Are you looking to get parameter value as string in dynamo?
Use custom node Lunchbox get parameter node.
http://dynamobim.org/forums/topic/cfm-and-units-something-is-awry/
Revit uses feet for length, which causes such issues
A conversion should solve your problem.
1 cubic feet = 28316.8 cubic centimeter
0.0255 cubic feet=722.06 cubic centimeter
Thanks to all, the problem is solved!
