Hi All,
This has been perplexing me for a while now. I have got the E/W and N/S coordinates from the Project Base Point and wanted to subtract this value from a list of coordinates but Dynamo will not perform the calculation on the list? Any ideas why this may be? I have checked that it is a number and as you can see from the image, this works fine if a manually add the number into a Code Block. I am guessing its a quirk with the way the Revit parameter is held?
Cheers,
