Hello all,
I’m trying to create visuals using calculated values that were pulled from schedules. These come into the graph using lists that are aimed at using them as inputs for a pie chart. When I run the script using the lists I’m receiving a null value from the data shapes node. However, using the same lists through the NodeModelCharts pie chart node achieves what I’m looking for. I’d like to use DataShapes though as it provides a pop up than I intend to use on the DynamoPlayer when working in Revit.
In other examples of using the Data Shapes method the value is often inserted by a list count node, so I’m guessing perhaps this is why I’m not able to use my list as it stands.
Any help would be greatly appreciated.
Thank you.
R
