Using Dynamo with Civil 3D for finding way of going around an object
Hi
I´m wondering if its possible?
For instance to use Dynamo with Civil 3D for letting a cable duct to go automatically around a mast along an alignment.
Hello @FKNZ
Probably something here ; Cabletray slides sideways
I guess its 2 different package…i only use that one for revit
dont know try on the link you shared…is it for civil 3d ? you want ? my exemple is for revit…thats why it is importent you give you post a categori…so we talk about the same
I recommend you look into VASA instead as it can find the path between two points with the least amount of run overall.
I have already masts placed as blocks by dynamo and cable duct modelled in civil 3d and want to find a workaround from here :thinking:
No idea what a mast is, but VASA can find the best path from point A to point B avoiding obstacles C-Z. Watch the ‘comprehensive guide’ on YoutTube.
