%UserProfile% support
Why doesn’t dynamo support the use of %UserProfile% in file paths and directory paths?
Is there a workaround?
Thanks is advance
Ah they take file paths as strings so no support for this. I would bring this up here:
Ps. Here’s a simple solution to doing this on your own in Python node for example:
Hello @Konrad_K_Sobon,
I have the same problem with a path. Our files are stored in OneDrive.
Each user has the files sincronized, and always stored on their computer.
My programming skills are very low, and I am not able to create a python script to solve the problem.
Could you help me?
Use that Python-Code:
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
import System
path = IN[0]
OUT = System.Environment.ExpandEnvironmentVariables(path)
@s.hofer6LSK7
He will definitely reply to your post 7 years later #sarcasm
