Is there a way for the file path node (set to “is input”) in the dynamo player to remember the selected file location?
When using the player, the file path node defaults to the preset path with the dynamo graph and will not be saved. If you open dynamo and file path to the correct location, this works, but I was hoping that the player could save the file path location.
Thanks!
