User Input for Dynamo Player - How to Access
So, I am a bit baffled, how do I make a node to be user input to show up in the dynamo player.
From the research I have done, I can right click a node and check a box that states “is input”?
When I right click a node, I do not have this option though. I guessing that this is something easy that I am missing?
test
Revit 2018, Dynamo 2.0.1
Thanks!
I’m assuming you are using renamed Code Blocks (that’s what they look like).
Code blocks can’t be inputs.
Try using a “Number” Node instead.
Joe
Yep, renamed nodes, which are code blocks
Thanks Joe, this did the trick!
also you can explore Data-Shapes package.
hi, any idea about setting as input a certain element of a list?
the code block says f, but i want to be able to choose X before running the script in Dyn Player.
how can i have X as a Number slider (as Input) and … a block that gets X from the Number slide? (f)
found it… i just wrote in a code block f [ x ] and it automatically generated a block with input for x :slight_smile:
this way x can be a number…and set as Input for Dynamo Player.
