How to Input a code block from Dynamo Player?
Hi everybody.
I created dynamo script, I want to input a code block from Dynamo Player. Please help me, how to input a code block from Dynamo Player.
Thank you so much.
Codeblocks cannot be used as inputs.
Use a number, string, number slider or other single entry basic data type node. These can usually make ranges and lists (such as what I think you’re after with the [1,2] block).
Alternatively you could look at the UI++ nodes in the Datashapes package.
Thank JacobSmall.
If I use the UI++ nodes in the Datashapes package. How to does its?
Please help me. Thank you so much.
something like that
you can use this concept as one of the options
input
or to use Data-Shape package as @yamanyildirim said
Thank @khuzaimah.ElecEng.
My array does not have 2 objects[1,2], but also many objects[1,2,3] or [3,9,10,15] etc … So I want to change my choice at Dynamo Player. No need to edit Dynamo scripts. Do you have solution for this way?
Thank @yamanyildirim.
it will work if you have a sequence , other that i think you need to use UI++
input2
or you can input the array as a string like this
Thank you so much. Very great.
Thank you @khuzaimah.ElecEng. Good job.
Thank you your solution for my problem.
Input value in Data-Shapes. How to save value of Data-Shapes for the next time. Do you have solution for this way?
Thank you so much.
