Hi all
Another basic question but I don’t completely get it yet.
I’m working in Revit 2014. I want to dynamo to select all walls of a certain type only so that i can join them all together.
any help would be appreciated.
Eugene
Hi all
Eugene
I believe that the easiest way to collect all walls of a certain type, is with Clockwork’s “All Elements of Family Type (Universal)” node:
As for the joining part, there are already some examples on manipulating the wall joins at the wall ends.
http://dynamobim.com/forums/topic/disallow-join-of-the-wall/
You’ll need to use a different method tho:
http://revitapisearch.com/html/e77a6d4e-bfbc-a146-0e29-54276bbb8056.htm
So a custom node is needed…I don’t feel like i’m missing the point completely now.
For the wall joining, it’s not quite a wall join. I’m using a 3mm thick wall as wall vinyl, so once I want to join the wall vinyl to the main plasterboard wall. This will then cut out the door openings, and others.
Thanks for the info though.
