Door Name same as Room Name
Hi @Mostafa_El_Ayoubi
I have followed your suggestion but I get the error in the “List.GroupByKey” node stating “Warning: List.GroupByKey operation failed. One or more input types are not matching. Lists as keys are not supported.”
Any suggestion? I am running revit 2017 and Dynamo 1.3.0875
I am driving mad. I have also tried with the “Door.Rooms” node and I got the same error
Thanks for any help
I have recently developped this script so you can take a look. it works really good in my projects and it has no python.
I have used Dynamo 1.2 version and Archi-Lab, Clockwork and LunchBox package.
Hi @klemklemklem
Thanks Kateryna for sharing the graph. Could you please upload image again as it is not readable.
Python is inside in archi-lab and clockwork package custom nodes :slight_smile: Cheers!
it iRooms renumbering Doors renumbering according to room number a lot of other struff.dyn (54.4 KB)
Hi @klemklemklem, The problem with the BoundingBox method is that you can’t really trust it :stuck_out_tongue:
Check this discussion: Element.Room node (Rhythm) package - null values
