I’m opening Revit 2020 and trying to test out scripts that work fine in Revit 2019, but when I open them in 2020, there are several nodes missing from the .dyn files. The “Watch”, “String”, and “Elements of Type” nodes are missing. Has anyone had similar issues when making the upgrade from 2019 to 2020?
This graph has a nodeview with id:fa68b801-0219-4019-b9fe-63dae1d9e63e and name:Watch, but does not contain a matching nodeModel
This graph has a nodeview with id:8e507b4f-d66e-4b08-b61a-6d4391056135 and name:String, but does not contain a matching nodeModel
Looks like your image or attachment didn’t post - can you reattach?
Or if you weren’t attaching and that was a log can you attach a dyn where this error occurs for you?
Here’s the dyn file and images of what I see in 2019 vs 2020. The 2020 log file gives me the following errors.
This graph has a nodeview with id:a708e52a-1e14-46ae-b70b-8050213ac407 and name:String from Object, but does not contain a matching nodeModel
This graph has a nodeview with id:21548c3d-6971-4edc-bab9-969dd95c3b6a and name:All Elements of Type, but does not contain a matching nodeModel
This graph has a nodeview with id:bdd44112-3ada-494c-beba-a47a2c8d01a1 and name:List Create, but does not contain a matching nodeModel
This graph has a nodeview with id:6c4f8760-c415-49ce-95ba-7bd786f7d00c and name:All Elements of Type, but does not contain a matching nodeModel
02-EXPORT DWF-SELECT LEVELS.dyn (86.7 KB)
