After updating from RVT18 to RVT19, I’m now facing a problem in opening my old Dynamo nodes I was working with. The error message says that “the node is damaged”.
Does anyone have any ideas about how to solve this issue?
can you provide a screen shot? which nodes? are they custom nodes, nodes from a certain package, OoTB node? We need more info to try and help. Can you droop the DYN here? What does the DYN do? Was the project saved in 2019 and re-opened prior to you running Dynamo?
Below you will find the error message (in Italian, sorry) which basically says “Error in opening de damaged file:D…”.
The version of Dynamo is the 1.3.3.411 and the node I’m trying to open is one I’ve created using a mix of standard nodes and checking it on RVT2018.
Today I’ve updated the model to RVT2019 and the nodes I wrote before shows that error in opening.
