Upgraded from Revit 2023 to Revit 2026 pyrevit custom toolbars do not run
OK I am stumped I recently upgraded from Revit 2023 to Revit 2026 and love it. my issue is that my custom toolbars do not work. I have upgraded the scripts so they play just fine from Dynamo, but for some reason it will not run (none of them) using pyrevit for my custom toolbar. It spins for a few seconds then nothing happens.
also now they also do not run in 2023 even though I created a new folder link so the dynamo files will not be upgraded.
any help would be great thanks in advance
I found this out and once I set it to Automatic they ran fine
Thanks for reporting your findings back!
Generally speaking, if there is a pyRevit issue, (if Dynamo is involved or not) it is probably better suited to ask over there, so I am glad you found the solution!
