Update omniclass
is it possible to update the new omniclass numbers with Dynamo ?
thanks
Haven’t done it myself, but here is a possible approach…
  • Save the OmniClassTaxonomy.txt file as an Excel document
  • Access and modify the required data
  • Write the data back to the excel document
  • Save it as a text file and replace the original
Or manipulate the text file…
File:OmniClass.dyn
20160510-2
Thank you so much Vikram , I will try it
@ASSILI_KARIM, any updates regarding method proposed by @Vikram_Subbaiah?
With the help of @Kulkul, @T_Pover and others, I was able to fill out most of the type parameters with Dynamo including the Keynotes by using a Placeholder workaround, so I’d like to be able to modify the Omniclass number also.
Regards,
Jonathan
