I am trying to update existing parameters of type “Shared”.
So want to be able to retrieve these parameters and adjust which categories these have.
I don’t want to create new parameters in the Shared Parameters file, only update the ones in the model.
I’ve tried some custom nodes but can’t get it to work the way I want.
Has anyone had success with what I’m trying to achieve?
You need to show us what you have so far and where you’re specifically running into issues.
Hi @Nick_Boyts
The error is at *collector = FilteredElementCollector(doc).OfClass(Definition)
“not a recognized Revit API type Parameter name: type”
def update_parameter_categories(parameter_name, new_categories):
t = Transaction(doc, 'History name for undo Transaction')
t.Start()
# Find the shared parameter by name
definition = None
for param_def in collector:
if param_def.Name == parameter_name:
definition = param_def
break
if definition:
# Clear existing categories associated with the shared parameter
definition.ClearCategories()
# Update categories associated with the shared parameter
for new_category in new_categories:
definition.AddCategory(new_category.Id)
print("Shared parameter not found!")
# Commit the transaction
t.Commit()
parameter_name = "RKL_Produkt_BSABe"
new_category = Category.GetCategory(doc, BuiltInCategory.OST_Walls) # Get the desired category
update_parameter_categories(parameter_name, [new_category])
I wouldn’t recommend getting your parameter definition this way, even if it did work as there is a built in property of the document class ParameterBindings.
If you really wanted to use the filtered element collector, you would likely want to look for a SharedParameterElement not a definition.
