I need help in trying to get rid of line that is found in Element.GetLocation. I selected only Structural Columns but some how This line pass through the System. Is there a way i can fine this line and get rid of it, or is their an easier way?
Likely a slanted column. Note that if you remove this the association with the elements, however you can use a List.RemoveIfNot with the geometry list as the list input, and the string “Point” as the type input.
Thank you for responding but can you give a visual representation of what I should do?
Not at my CPU at the moment, but itMs pretty straight forward. Put a List.RemoveIfNot node on canvas, wire the node you put a screenshot of into the list input, and then put a String node into the other input and write ‘Point’ in it and the resulting list should just be the points from the geometry list.
This is an example of how it it assembled in another context: Dynamo Dictionary
If you remove the Line are you not then going to end up with 1 Column less on your list, and therefore be missing whatever this script is doing for that one column?
If the goal is to get the centrepoint location of the columns is it not then better to impliment logic whereever there is a slanted column to take the point at curve 0.5 to get its relative location and replace the problem mentioned above with that item instead?
Or am i simply overthinking this?
well im gonna try to explain this to the best of my ability, you have to know im new to dynamo and im a visual learner. So i have a [Element.GetLocation] that is abstracting data from [All Elements of Category], to which im connecting it to a [Point.X], [Point.Y], and a [Point.Z]. from what I understand those points x,y, and z points will look at that Line from the [Element.GetLocation] and see it as a null cuasing those x,y, and z points not to work and then i get message saying that I need to convert non-convertible types. I tried using a drop Null, or clear list, SOMETHING, to get rid of these line or just forcing those x,y, and z points to accept it.
If anybody needs to pictures i will be glad to see them, but i suck at pasting pictures on here cus its blurry. or anyone can do i zoom call i don’t know, all i know is i need help ![]()
Once you get the X, Y, and Z data what are you going to do with them? It may be best to filter the elements by their location type as a first step.
From your list of selected elements:
Give it a shot and post where you get and the community will do what we can to help. ![]()
Use the export canvas as image feature by zooming so you can read one node clearly, and hitting the camera or ‘export’ button just outside the upper right corner of the workspace. Save that image and post it here or on a 3rd party service (if you lack permissions here) and link us to it.
Do i have to use a [Code Block “line”;] and attack it to the [SearchFor] connector on the String.Contains?
Thank you problem fix, also on my post i have a topic called array nodes if you can, please take look at it?
thank you, also if you want take look at one of my topics “array nodes” if you want to take a look at it?
