Unresolved Node from package
Hi all,
I am trying resolve the node from Lunch box package. At the beginning I have installed the latest version of package but later on I have uninstalled the package and I have installed the older version i.e Lunch box - 2016.11.11 version.
But still I am getting the same error. I have restarted my system after installing it. But still the same error.
Can any one please tell me the solution.
lunchbox package error
Hello @shashank.baganeACM ,
After installing the Lunchbox - 2016.11.11 , can you check whether this package is there in out system or not. if its there then connect then current string with new node
Hi @honeyjain619 It is not showing in the out system.
and If I try to publish it then it will show in the system addons but all the nodes are not loaded.
If I restart my dynamo then it will disappear. I have checked the manage node and package paths and even I have checked show graph dependencies, it is showing me in the green color.
Can you please tell me why it is behaving weirdly ?
The primer has Lunchbox included as a resource (zip file)
  1. download from here: Useful Packages | The Dynamo Primer
  2. Unzip with 7zip preferably. (If not using 7zip be sure to unlock the zip before extracting)
  3. Place in your package folder.
