Hi Guys,
I have been working on a small use case “Dynamic script to update parametric values”.
Based on user inputs the script will update the specific parameters of a family instance with new values from excel.
When I am trying to do it, it is updating values from excel but into different conversions. On the other hand dynamo node is updating properly.
My code:
import sys
sys.path.append(r'C:\Program Files\IronPython 2.7\Lib',)
libraries = IN[0]
sys.path.append(libraries)
import pandas as pd
clr.AddReference("ProtoGeometry")
from Revit import *
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory, BuiltInParameter, ParameterValueProvider, ElementId, ElementParameterFilter, FilterNumericEquals, FilterElementIdRule
#Inputs
elements = UnwrapElement(IN[1])
parameter = IN[2][0]
path = IN[3]
sheetName = IN[4][0]
column = IN[5][0]
#Excel
excelWorkbook = pd.read_excel(path, sheet_name=sheetName)
excelWorkbook = (excelWorkbook.drop_duplicates(subset=["properties.Text.IDK Positionsnummer"])).reset_index()
#Revit family instances
for elem in elements:
IDK_elementPosNum = elem.LookupParameter("IDK Positionsnummer").AsString()
for i in range(len(excelWorkbook)):
IDK_excelPosNum = excelWorkbook["properties.Text.IDK Positionsnummer"][i]
if IDK_elementPosNum == IDK_excelPosNum:
elem.LookupParameter(parameter).Set(excelWorkbook[column][i])
break
pass
OUT = 0
I tried using doc.GetUnits().GetFormatOptions(UnitType.UT_Length).DisplayUnits, and some more workaround procedure from forum. But getting errors.
How to make the unit conversions? How to make it dynamic but not like hard coding “UT_length, UT_MassDensity…”?
Whole script as PNG for reference:
