Uneven Room Boundary Handling
I have a multiple rooms or space i need to get the boundary for distribution. i am not getting complete 4 point boundary in rectangular room line created for each perpendicular wall.
Kindly Suggest any workflow or process to get the curve based linear or Grid based fixture placement using dynamo.
Hi …Try closed loop by curve and a polycurve simplify
I want to divide the line for distance of x. on all 4 sides. How i divide this.[quote=“sovitek, post:3, topic:98517, full:true”]
[/quote]
allright probably i misunderstand…i just mean something…
This is my Room and i have highlighted in the different color for placing sprinkler fixture. kindly suggest the workflow for this i have tried but i failed. Here i have Attached the Script also.
Sprinkler Placement by NFPA.dyn (256.8 KB)
not sure, do you want simplefy your room boundery curve, then try what i already suggest or get the room/space surface and the perimeter curve…but not 100 if it what you try
Why not join the boundary curves into a polycurve before you offset?
