Unable to create wall by API
Hi everyone
I’m getting the following error in the Revit Python Shell console (that I guess it would be the same by using python in dynamo ) when attempting to create walls:
Exception : Microsoft.Scripting.ArgumentTypeException: expected BuiltInParameter, got ElementId
I guess it’s related to the level Id which I can’t define correctely
Pls check my code below:
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
selection = uidoc.Selection.GetElementIds()
wall_Types = FilteredElementCollector(doc).OfCategory(BuiltInCategory.INVALID).OfClass(WallType).ToElements()
level_Types = FilteredElementCollector(doc).OfCategory(BuiltInCategory.INVALID).OfClass(Level).ToElements()
for w in wall_Types:
    if w.Name == "Ext. Voile BA 20":
        wall_Id = w.Id
for l in level_Types:
    if l.Name == "Niveau 0":
        level_Id = l.Id
t = Transaction(doc, 'Create walls')
t.Start()
for s in selection:
    crv = doc.GetElement(s).GeometryCurve
    wall = Wall.Create(doc, crv, ElementId(wall_Id), ElementId(level_Id), 3.00, 0.00, False,True)
t.Commit()
How to solve this issue?
Thanks.
They are already element Ids, don’t pass them in to the element Id class.
@GavinNicholls
I tried it the first time as you mentioned, but bizarrely, it did not work. Then it worked the second time.
Thanks a lot.
