Can not create walls by lines
Hi all,
I’m using Revit python shell and I’m traying to create walls from lines using profil method as described below:
But I’m getting the following error in the RPS console, which I suppose would be the same in Dynamo.
Exception : Autodesk.Revit.Exceptions.InvalidOperationException: Could not construct a proper face with the input curves to create a wall correctly.
à Autodesk.Revit.DB.Wall.Create(Document document, IList`1 profile, ElementId wallTypeId, ElementId levelId, Boolean structural)
Here my code:
from System.Collections.Generic import IList, List
uidoc = __revit__.ActiveUIDocument
doc = uidoc.Document
t = Transaction(doc, 'create Model lines')
wall_Types = FilteredElementCollector(doc).OfCategory(BuiltInCategory.INVALID).OfClass(WallType).ToElementIds()
levels = FilteredElementCollector(doc).OfCategory(BuiltInCategory.INVALID).OfClass(Level).ToElementIds()
for w in wall_Types:
    w_type = doc.GetElement(w)
    if w_type.Name == "Ext. Voile BA 20":
        wall_Id = w
for l in levels:
    lvl = doc.GetElement(l)
    if lvl.Name == "Niveau 0":
        lvl_Id = l
# Create Points and Lines:
c = 1/0.3048
Pt0 = XYZ(-0.60*c,-0.60*c,0)
Pt1 = XYZ(0.60*c,-0.60*c,0)
Pt2 = XYZ(0.60*c,0.60*c,0)
Pt3 = XYZ(-0.60*c,0.60*c,0)
Lines = []
Line1 = Line.CreateBound(Pt0, Pt1)
Lines.append(Line1)
Line2 = Line.CreateBound(Pt1, Pt2)
Lines.append(Line2)
Line3 = Line.CreateBound(Pt2, Pt3)
Lines.append(Line3)
Line4 = Line.CreateBound(Pt3, Pt0)
Lines.append(Line4)
Curves = List[Curve]()
for i in Lines:
    Curves.Add(i)
t.Start()
Walls = Wall.Create(doc, Curves, wall_Id, lvl_Id, True)
t.Commit()
Any help would be appreciated
Thanks.
Hi @REDO10
Z values cannot be identical
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
TransactionManager.Instance.ForceCloseTransaction()
wall_Type = FilteredElementCollector(doc).OfClass(WallType).WhereElementIsElementType().First(lambda x : x.ToDSType(False).Name == "Générique - 200 mm")
level = FilteredElementCollector(doc).OfClass(Level).First(lambda x : x.ToDSType(False).Name == "Niveau 1")
c = 1/0.3048
Pt0 = XYZ(-0.60*c, 0, -0.60*c)
Pt1 = XYZ(0.60*c, 0, -0.60*c)
Pt2 = XYZ(0.60*c, 0, 0.60*c)
Pt3 = XYZ(-0.60*c, 0, 0.60*c)
Lines = []
Lines.append(Line1)
Lines.append(Line2)
Lines.append(Line3)
Lines.append(Line4)
for i in Lines:
    Curves.Add(i)
t.Start()
wall = Wall.Create(doc, Curves, wall_Type.Id, level.Id, True)
t.Commit()
OUT = wall
Hi @c.poupin
Effectively, I discovered my mistake and corrected it. I initially chose the wrong method, which created a wall profile based on lines in the XZ or YZ plane, but I wanted to create walls based on lines in the XY plane. To solve this, I should have used the method you employed, which resolves my issue.
Thanks a lot Cyril :wink:
