UI Selection - PickBoxStyle not defined
Hi All,
Ive got a small headscratcher here with using the PickBox() selection method in the Revit API.
For some reason the PickBoxStyle is not recognised.
Have I missed loading a reference or is this something else?
Revit 2018
Dynamo 1.3.2
clr.AddReference)'RevitAPI')
from Autodesk.Revit.DB.Events import *
pickedBox = uidoc.Selection.PickBox(PickBoxStyle.Enclosing, "Select a box")
OUT=pickedBox
@Kulkul?
@Mostafa_El_Ayoubi?
Got it, had to be a bit more specific when creating the PickBoxStyle. :man_facepalming:
clr.AddReference('RevitAPI')
pboxS=Autodesk.Revit.UI.Selection.PickBoxStyle.Enclosing
pickedBox = uidoc.Selection.PickBox(pboxS, "Select a box")
OUT=pickedBox
Hi @Ewan_Opie ,
Thanks for this code ! I am currently working on something similar and I would like to convert user pickedbox to points, curves, …etc in order to place a schedule according to user selection in sheets.
Do you think it is possible to create a list of curves or points out of the user selected area ?
I’ve tried using your code with the dynamo nodes (element location, curves, BBox, …etc.) but it doesn’t give anything.
Thanks in advance
Hi @a.halim
There are other pick-point examples on the forum for individual points.
Have a look at this for a starting point with pickbox rectangles :wink:
D2_Pickbox to Curves.dyn (42.7 KB)
@Ewan_Opie , this is just perfect :smiley:
Thank you so much !!
Hi again @Ewan_Opie ,
the script works perfectly for selecting a region from any view. Even with sheets, which is great.
However, I tried to use the rectangle center-point to place a schedule view, but it is being placed very far from the selected region.
What do you think is the reason ?
Could be a Revit XYZ converstion issue.
Try using this code in a python block.
It requires list inputs.
# Import geometry conversion extension methods
# Import RevitAPI
app = uiapp.Application
sheets = []
for i in IN[0]:
	sheets.append(UnwrapElement(i))
views=[]
for i in IN[1]:
	views.append(UnwrapElement(i))
points=[]
for i in IN[2]:
	points.append(UnwrapElement(i).ToXyz())
# Start Transaction
viewp=[]
#for s in sheets:
#	for v,p in zip(views,points):
#		a=Viewport.Create(doc, s.Id,v.Id, p)
#		viewp.append(a)
cnt = 0
for cnt in range(len(sheets)):
    a=Viewport.Create(doc, sheets[cnt].Id,views[cnt].Id, points[cnt])
    viewp.append(a)
# End Transaction
OUT=viewp
