pvhuyg
March 25, 2019, 6:34am
#1
I want to display view on winform? Can you help me
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
clr.AddReference('RevitAPI')
import System
from System.Windows.Forms import *
from System.Drawing import *
import System.Drawing
import System.Windows.Forms
preview = PreviewControl(doc,doc.ActiveView.Id)
class MainForm(Form):
def __init__(self):
self.InitializeComponent()
def PreviewHost(self):
self = System.Windows.Forms.Integration.ElementHost
def InitializeComponent(self):
self._button1 = System.Windows.Forms.Button()
self.SuspendLayout()
# button1
self._button1.Location = System.Drawing.Point(291, 408)
self._button1.Name = "button1"
self._button1.Size = System.Drawing.Size(75, 23)
self._button1.TabIndex = 0
self._button1.Text = "button1"
self._button1.UseVisualStyleBackColor = True
self._button1.Click += self.Button1Click
# MainForm
self.ClientSize = System.Drawing.Size(391, 457)
self.Controls.Add(self._button1)
self.Name = "MainForm"
self.Text = "preview"
self.ResumeLayout(False)
def Button1Click(self, sender, e):
pass
form = MainForm()
form.PreviewHost.Child = preview
form.ShowDialog();
OUT = preview
Depending on what you are after doing with a winform, it may be best to have a look at the datashapes package because this will create winforms depending on your given inputs. just have a look at the below blog posts for how it can work.
Blog post: https://data-shapes.io/blog/
pvhuyg
March 25, 2019, 10:05am
#3
i want preview view put into UI winform
Data-shapes slow down the process
What sort of errors are you getting in dynamo when you run your code?
If you look on the revit api for the preview control it states the following that should help you make the correct form type - “The dialog or form or window host this preview control must be modal. The view can be any graphical view but not a non-graphical view. And only one can be active. The view can be manipulated by embedded view cube and the visibility and graphical settings set on the view will be evident in the preview control.”
Also you could look at the data shapes python code for the UI’s to help understand what is happening. Then it should help you adjust yours accordingly?
@pvhuyg Could you re-edit the code you posted please. There is a problem with the quotes everywhere.
pvhuyg
March 26, 2019, 1:24am
#6
import System
def __init__(self):
self.PreviewHost()
self.PreviewHost = System.Windows.Forms.Integration.ElementHost
self._panel1 = System.Windows.Forms.Panel()
# button1
# panel1
self._panel1.Location = System.Drawing.Point(25, 24)
self._panel1.Name = "panel1"
self._panel1.Size = System.Drawing.Size(341, 365)
self._panel1.TabIndex = 1
# MainForm
self.Controls.Add(self._panel1)
self.PreviewHost.Child = preview
pass
form = MainForm()
form.ShowDialog()
OUT = preview
pvhuyg
March 26, 2019, 1:27am
#7
sory. I fixed it. I want to get Integration from System.Windows.Forms but failed
