Hello guys,
I found that OpenSource project but it is in C#. I could not manage to translate Classes into Python. Can someone take a look?
Thank you very much!
Hello guys,
Hello @Deniz_Maral
very interesting
Thank you very much Cyril! I had a problem with converting a lambda function that pass EventHandler activities. I tried it also in WinForm but it was an empty window.
Not sure if this could help, but seems to be in line.
Hello Sean,
thanks for sharing it but I know it already. I donât know how to reference a Class in Windows Class that referenced in xaml.
I took a look and it looks very interesting
try this
import sys
import wpf
clr.AddReference("System.Xml")
clr.AddReference("PresentationFramework")
clr.AddReference("PresentationCore")
clr.AddReference("System.Windows")
import System
from System.IO import StringReader
from System.Xml import XmlReader
from System.Windows.Markup import XamlReader, XamlWriter
from System.Windows import Window, Application
#import Revit API
clr.AddReference('RevitAPI')
#import Revit APIUI namespace
class PreviewControlRevitAPI(Window):
def __init__(self, xaml):
#collecotr = FilteredElementCollector(doc).OfClass(DB.View)
self._xaml = xaml
xr = XmlReader.Create(StringReader(self._xaml))
self.winLoad = wpf.LoadComponent(self, xr)
self._previewControl = PreviewControl(doc, doc.ActiveView.Id)
self._previewControl.Loaded += self.PreviewControlLoaded
self._grid1.Children.Add(self._previewControl)
def PreviewControlLoaded(self, sender, e):
self._previewControl.UIView.ZoomToFit()
xaml = """
<Window
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
Title="Preview Control"
Height="500"
Width="500"
ResizeMode="NoResize"
mc:Ignorable="d">
<Grid>
<Grid
Name="_grid1"
HorizontalAlignment="Left"
VerticalAlignment="Top" />
</Grid>
</Window>"""
preview = PreviewControlRevitAPI(xaml)
preview.ShowDialog()
OUT = 0
Note only works with IronPython, thanks @chuongmep for the repo
Oh my god! It works, merci Cyril!
I could not manage to manage that oneâŚ
What does += or -= without a loop?
Are they async and await in C#?
https://docs.microsoft.com/de-de/dotnet/csharp/language-reference/keywords/async
import sys
import wpf
import System
#import Revit API
output = []
views = FilteredElementCollector(doc) \
.OfCategory(BuiltInCategory.OST_Views).WhereElementIsNotElementType() \
.ToElements()
view_names = [i.Name for i in views]
self._xaml = xaml
self._grid1 = self.winLoad.FindName('grid1')
self.viewNames.ItemsSource = view_names
def changeView(self,sender,e):
selectedView = self.viewNames.SelectedItem
.ToElements()
indexV = view_names.index(selectedView)
idView = views[indexV]
output.append(idView.Id)
xaml = """
<Window
Height="500"
Width="500"
mc:Ignorable="d">
<DockPanel HorizontalAlignment="Stretch" DockPanel.Dock="Top">
<StackPanel DockPanel.Dock="Top">
<Label x:Name="prompt_lb" FontWeight="Bold" Padding="0,0,0,5">Ansicht auswählen</Label>
<ComboBox x:Name="viewNames" SelectionChanged="changeView"
Height="30"
IsEditable="True"
FontSize="14"
VerticalContentAlignment="Center"
StaysOpenOnEdit="True"/>
</StackPanel>
<Grid
Name="grid1"
</DockPanel>
</Window>"""
OUT = output
I added a dropdown which you can select a view and switch to it but I get an error that I can only open one view. Which method can I use to change view? I got somehow ViewId but assigning it, I could not find the right function.
Ok I found the solution:
import sys
import wpf
import System
#import Revit API
output = []
.ToElements()
self._xaml = xaml
.ToElements()
self._previewControl.Dispose()
self._previewControl= PreviewControl(doc, idView.Id)
xaml = """
<Window
Height="500"
Width="500"
mc:Ignorable="d">
Height="30"
IsEditable="True"
FontSize="14"
</StackPanel>
<Grid
Name="grid1"
</DockPanel>
</Window>"""
OUT = output
@c.poupin how can I use variables of a method insinde of another method?
For example: In order to get views, I had to collect them again in changeView function. I created a new function and letâs say I want to get view_names from changeView. How can I do it in Python?
Would love to see a little movie clip or screenshots of your final product here @Deniz_Maral.
use the âselfâ keyword instance of the class
here some change
EDIT : code updated for compatibility with the 2 Pythons engines
import sys
import System
from System.Windows import LogicalTreeHelper
#import Revit API
filterP = System.Predicate[System.Object](lambda x : not x.IsTemplate)
self._views = List[Element](FilteredElementCollector(doc)\
.OfCategory(BuiltInCategory.OST_Views)\
.WhereElementIsNotElementType()\
.ToElements())\
.FindAll(filterP)
self._dictView = {i.Name : i for i in self._views}
self._xaml = xaml
self.winLoad = XamlReader.Load(xr)
self._grid1 = LogicalTreeHelper.FindLogicalNode(self.winLoad, "grid1")
self._viewNames = LogicalTreeHelper.FindLogicalNode(self.winLoad, "viewNames")
self._viewNames.ItemsSource = sorted(self._dictView.keys())
self._viewNames.SelectionChanged += self.changeView
selectedViewName = sender.SelectedItem
idView = self._dictView.get(selectedViewName)
xaml = """
<Window
Height="800"
Width="1200"
mc:Ignorable="d">
<Label x:Name="prompt_lb" FontWeight="Bold" Padding="0,0,0,5">Select View to Show</Label>
Height="30"
IsEditable="True"
FontSize="14"
</StackPanel>
<Grid
Name="grid1"
</DockPanel>
</Window>"""
preview.winLoad.Show()
OUT = 0
Great tips! I added another combobox to select family and then try to get its views. My script works but I did not manage to write Class methods like you very clean.
If you select Family which is editable:
views = FilteredElementCollector(doc.EditFamily(fam)).OfClass(View)
self.viewNames.ItemsSource = new views
This is fantastic! However, much simple using C#
I meant: how can I for example use views var in change view in changeFamily method. I get always an error:
try this
I update the code in my previous post for compatibility with the 2 Pythons engines
Not from Jealous ![]()
and
saved my life
I was always wondering what sender does⌠Just perfect!
