I 've got two issues :
1- After install the version 0.7.4.0 ==> clicking into Revit the Dynamo Icon ==> Dynamo software doesn’t start. Starting manualy from the folder Program file ==> it appear i doesn’t have Revit functions (for your information My Revit version : Revit 2015 R2 20140905_0730(x64))… Do you know the workaround solution?
2- Unsing the version 0.7.1.17276 (it work with my revit) ==W when i try to get parameter from element by name, i’ve got an issue concerning name with accent for instance “Niveau supérieur”.
I use a Revit with French interface (see the screen capture) Do you know the workaround solution?
Best regards
Olivier Bayle Autodesk
