I am trying to get the “Insulation Thickness” value from a duct fitting. There are two parameters with this name, 1 under the “Insulation” group, and 1 under the “Mechanical” group. I need the value under the “Insulation” group which is 25mm, but it keeps giving me the value under the “Mechanical” group which is 0.
I have tried the “Get built in Parameter” node but I get a very different value to 25mm.
Not the ‘answer’ but it will hopefully point you to it: Revit uses decimal feet for pretty much all measurements under the hood, and converts to the project values for display. So… What is 25mm in feet?
I tried this earlier but I thought it was going to be in inches not feet, so I tried converting from inches to mm which obviously didn’t work:)
Sometimes you just need a new set of eyes looking at it.
