Hello guys
I am extracting different parameters from a Mechanical Revit model. I could extract all parameters properly except “Insulation Thickness”. It gives me zero value for all of them, but I have some elements with non-zero insulation thickness value. It only happened on Duct Fittings category (Please see the attached pics). For other categories such as Ducts and Duct Accessories Dynamo could extract the right values of each element. I used the same workflow in my script. As I said, for Ducts and Duct Accessories it worked, but for Duct Fittings it does not work. Do you know where the problem is? Thanks
