I am new to this forum and I have started learning dynamo through the tutorials on the website. However, I cannot open the Advanced Tutorials for Dynamo 1.X at this address: https://dynamobim.org/#videoTut
Has anyone had same issue with the videos, and have any advice on this for me?
@FatemehZangi it is worth noting that version 1.X is quite old now and we typicallt use 2.X builds these days in revit 2020 and beyond. 2.0.4 can be installed in older versions manually.
I’d suggest sticking to the 2.X primer/resources where possible.
@solamour might be an issue with the 1.X resources if they’re still being maintained.
I would Echo @GavinNicholls here and recommend sticking to the 2.X series!
The 1.X stuff is conceptually useful, but quite deviated now from modern Dynamo. Nodes named differently, approaches refined, UI changed etc. Once you are familiar with Dynamo they can help educate from a theoretical perspective, but to start would just cause confusion.
@FatemehZangi - After a lot of investigation we found that our hosting of the videos had been shutdown from another part of Autodesk. We are now back up and running on the Dynamo Youtube Channel - Advanced Tutorial set where you can watch them!
We are working on updating the website links directly from these Youtube hosted videos
Thank you so much for your help and updating us. This a helpful source for learning - I will continue watching them along with the sources for updated versions.
You are most welcome @FatemehZangi ! Hopefully they are fruitful to you on your Dynamo journey and open doors not yet opened to worlds not yet imagined
