Trying to filter by last number of Element Name
Trying to group all element names that end with same last number together. In the end I want to insert image to family image parameter. Grouping all 0-9 separately.
Hi and welcome!
Just FYI, here is a guide on how to ask for help on the forum:
Could you explain what your goal is, and what isnt working for you?
Hi @CKD ,
2023-10-25 (Sort and) Group elements by string-value within name.dyn (11.8 KB)
PS: You don’t need the List.SortByKey, but I always add it such that it’s sorted nicely.
This is great and thank you! Is there still a way to only end with the last number such as 0-9? instead of the group ending in 2-3 number values?
Yes, you could use String.Substring to only get the last letter or number in the string. In this case instead of the String.Split and List.LastItem nodes.
I am way out of my understanding. :frowning:
The basic nodes pretty self explanatory. You even get a small explanation when you hover over the node
But you have to put in some effort yourself.
The issue I am having is the number contains 2 or 3 values at the end. I need it to start at the end and don’t know how honestly.
Couln’t make that out of your original post to be honest.
Also you are given some pointers to have a go at it yourself.
Then, if you’re still stuck, show what you have came up with so far and we can help you from there.
NB
@Daan his solution still applies in your case (i think).
Thank you Got it!!
