I can’t open several definitions and custom nodes, getting this error:
Error opening file: ‘>’ is an unexpected token. The expected token is ‘=’. Line 32, position 71.
System.Xml.XmlException:
at System.Xml.XmlTextReaderImpl.Throw(String res, String args)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at Dynamo.Models.DynamoModel.OpenFileFromPath(String xmlPath)
at Dynamo.Models.DynamoModel.ExecuteCommand(RecordableCommand command)
at Dynamo.ViewModels.DynamoViewModel.Open(Object parameters)
dynamo 0.7.6 standalone with the example definitions for dynaworks from
Does somebody have an idea?
Thorsten
