I have written a dynamo file for bulk adding shared parameters on my main workstation. I’m using the revit dynamo plugin.
Now I tested, if I can run it on an other system. I copied the file and tried to load it with the same revit version (2018).
I get this error (translated):
Error opening the corrupted file: E:\Insert_Shared_Parameter_V1.dyn
- with this details:
System.Xml.XmlException: Ungültige Daten auf Stammebene. Zeile 1, Position 1.
bei System.Xml.XmlTextReaderImpl.Throw(Exception e)
bei System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
bei System.Xml.XmlTextReaderImpl.ParseDocumentContent()
bei System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
bei System.Xml.XmlDocument.Load(XmlReader reader)
bei System.Xml.XmlDocument.Load(String filename)
bei Dynamo.Models.DynamoModel.OpenFileFromPath(String xmlPath, Boolean forceManualExecutionMode)
bei Dynamo.Models.DynamoModel.ExecuteCommand(RecordableCommand command)
bei Dynamo.ViewModels.DynamoViewModel.Open(Object parameters)
The suspicious is, that this only happend if I create or change the file on my mainstation. Then I can run/open it ONLY on my mainstation.
When I create it on my teststation, I can run it there AND on my mainstation.
On my mainstation is the newest dynamo, which i downloaded from the website and installed it per “hand”.
On my teststation is the dynamo, which comes with revit 2018.
While I’m a new user, I can’t upload the .dyn. But it’s only a SharedParameterFile - Node and a Python Script - Node.
I hope you can help me.
Greetings
Buliph
