Trim node
Hi! I wish to divide this circle in small pieces, as on the right side of the 1st image.
So I created a grid by offset lines and then I used the trim node. But it doesn’t worked very well and I don’t know where is the problem. I have already changed slightly the coordinates of the points to avoid the lines but it seems that it is not the problem.
Has anybody else met this before?
Dividing test.dyn (47.2 KB)
There are many ways to do it…
Make a surface of the circle and use Geometry.Intersect. I think this is one of the easiest ways.
something like this?
Thank you ! tha’s exactly what i am looking for !
