Hey everyone,
I have this scheme and I try to translate these 2 points, based on the array of IN[1] in the yTranslation
How I should create the array to be able to translate it?
Thank you!
Hey everyone,
Thank you!
maybe just plug in the code block into the Geometry.Translate yTranslation?
Have you tried plugging the array in the Geometry.Translate node and set the node lacing to Vectorial Product ?
The scheme is working but does not create the array.
Hi Nick,
It works, but I need an array from the first number to those 5 specific distances.
I’m not sure I follow. That’s what it should do. Unless you mean 5 different arrays - in which case, what spacing are you using?
