I have a lot of models that needs to be checked for quality, wall types, wall names etc…
What I want to do is the following: I have one good model with all correct ellement, views and view templates. I want to “transfer” the view template from the correct model to all other rvt files. Is there a way to do that?
I googled a lot, but no succes. your help would be appreciated.
Thanks for your reply Nick, I tried that…but have little knowlege of how to do it in Dynamo…Anyway…I started to creat a view filter in Dynamo to apply on my views…
I was suggesting you do it manually. How many projects do you need to check? And I assume you’ll have to open each model to check anyway right? So there’s not really an extra step. Or are you trying to run the checks in a background document?
well…I have thousands of models to check…I have to check all the walls for functionality… I want to creat new views (multiple levels) and apply filters to them so I can check by colour and where needed alter the family…
But are you automating the checks or do you have to open each model, look for problematic areas, then alter the family? If you have to open each model anyway manually transferring view templates is an option. I agree it’s not as good as doing it through Dynamo, but I don’t know if that’s even possible. There’s an EventArgs class for Transfer Project Standards but last I heard running the command wasn’t available in the API.
Your other option is to export all the view template data from your good project to Excel. Then use that data to recreate the same template in the other projects. However this is likely a lot of information that would be slow to transfer, especially to thousands of models. This is why I think you’d have more luck manually transferring view templates via project standards. Someone else may have a better solution though. I’ve never tried transferring a view template with Dynamo.
You right that I can transfer project data. But through Dynamo I am able to create views with the correct view names, etc. The only thing that I need is to distinguish the walls by 'type parapeter: Function" and apply a color. I have created the filter, added it to a view, but I can’t succeed in applying a color, pattern to the filter. I dont know what I am doing wrong…maybe you can have a look at that…I would really appreciate that.
I have one question which is similar to this. I need to create a script about transferring views with assigned view templates to another project. I would like to know is this possible at all? I managed to create the script for transferring all views and view templates but all view templates in another project are not assigned to views like in original project.
