I’m trying to create a node that can change the linestyle of a filled region passed into it. I currently have a working script that takes ina graphic style and a filled region and changes the linestyle, this requires a transaction. It work’s properly when run in manual mode, but when put into automatic mode, the transaction runs over and over and over again, until I force close the whole project. Is this normal for a python node that contains a transaction in it? All transactions must be used in manual mode? Or is there something that is wrong with my code. Here it is:
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import DocumentManager and TransactionManager
clr.AddReference(‘System’)
from System import *
Import ToDSType(bool) extension method
app = DocumentManager.Instance.CurrentUIApplication.Application
#These are my inputs for the Node
gStyle = IN[0]
filledRegion = IN[1]
#Declared Variables
output = list()
count = 0
for i in filledRegion:
count = count + 1
#Check each filled region
for i in range(0, count):
UnwrapElement(filledRegion[i]).SetLineStyleId(ElementId(gStyle[0].Id))
output.append(filledRegion[i])
OUT = output
If needed, I can post the DYN and a sample Revit File. Any help would be awesome. Thanks.
