in reference to http://dynamobim.org/forums/topic/excel-roundtrip-fill-patterns-line-styles-etc/ I tried to apply the concept to Line Styles names without going through the excel part.
all seems fine until I try the apply the code from @Konrad_K_Sobon. Maybe it is because it is from 2015 and some things have changed in the API
Basically if I keep the code intact I get “unexpected token ‘import’”
and if I remove some of the dependencies I get " the element does not support user specified name "
any clue as to what I am doing wrong would be appreciated:
clr.AddReferences(“RevitAPI”)
import Autodesk.Revit.DB import *
app = uiapp.Application
dataEnteringNode = IN
fillPatElems =
for i in IN[0]:
fillPatElems.append(UnwrapElement(i))
values = IN[1]
for i,j in zip(fillPatElems, values):
i.Name = j
OUT = fillPatElems
Given the import warning you got I’m guessing this code might have been copied and pasted from a quote block as you have pasted your code here? It would have turned the apostrophes and quotes into open and close symbols, which will not work in the Python editor, and caused problems with importing. I can’t quite discern what else could be wrong with the imports not having seen pasted as preformatted text.
(code should be pasted as preformatted text using this button here. quote blocks also eliminate indentations which are important)
Try copying and pasting the following:
clr.AddReference('RevitAPI')
import System
fillPatElems = []
for i in IN[0]:
values = IN[1]
i.Name = j
OUT = fillPatElems
thanks for the reply @awilliams
it does clear the import issue.
but I still get the following error:
I feed it with two lists: ids of graphicstyles and new names
