Hi
I have a problem with my script or more specific the “Elements in space” node from archilab. im trying to give the ducts in the specific space to share a parameter value of “Korrosivitetsklass”. This script doesn’t work in the project im trying on but if i change project it works perfectly. i get fault code “traceback” or "null "even if i get values from all the other nodes that is connected to “elements in space”
any tips?
korrosivitetsklass|690x446
Which version of archi-lab do you use?
we solved the problem by removing the excisting spaces in the project and replaced them with new ones. i dont know why it solved the problem but it did. im using dynamo 2.0.3 and archilab 2019.2.23 for Revit 2018.3.
