Toposolid nodes
How to get Poly surface from TopoSolids?
old nodes required Topology , while connecting TopoSolid to get Poly surface, gives error.
are there any nodes which can wirk with Toposolid?
Hello @Parshav_Kansara do you mean something here…
Hi Sovitek
Used your script as part of a larger script and works a charm!!!
(1) Curious though is there anyway to modify it to see the underside of a toposolid whereby I may have another toposolid (sub surface soil layer) cutting it, thereby eliminating the requirement to duplicate the script to select the subsurface layer
For context please refer to this link: Align Top Bottom Column with Toposolid - Revit - Dynamo (dynamobim.com)
