Topography adjusting points
Hey guys,
I had to adjust to topography a my project. All the points had to be lowered by 200.
Getting the points, adjusting the z-values was no problem. Putting those new point values back to the original topo was though … I ended up with creating a new topo based upon the new point values.
Downside:
I have to remove the old topograhpy and therefor all my buildingpads are deleted as well.
Question:
Is there a way to adjust the points of a topography?
A screenshot of your graph would help to quickly see what this issue is about. Did you also see what’s in this conversation?
I haven’t tried it, but there seems to be a Revit API method for this:
@Yna_Db see attached. Topograhpy by points creates a new topo and that’s what I currently have. But this doesn’t change the current topography. Capture
@Einar_Raknes hmm interesting, will have a look at that.
There is some additional information about “Editing a TopographySurface” in pages 68-70 of this document
Not sure if this is still the case but last time it was not possible to edit a topo from within Dynamo:
May have to read the building pads and recreate those as well. I’d consider storing their points in a CSV so you don’t have to chase your tail too much.
Could this be of help from Karam Baki,
Theres a whole data thing before it to adjust topos to edges.
# Created By Karam Baki : karam@aecedx.com
# Enable Python support and load DesignScript library
# IMPORTANT : ALL DYNAMO DESIGN SCRIPT NODES ARE AS (dg)
from Autodesk.DesignScript import Geometry as dg
# EXTENSION Enable ToDSType
# Enable Revit Elements
from Revit.Elements import *
# EXTENSION Enable Geometry Conversion Methods
# Enable Revit API
clr.AddReference('RevitAPI')
import Autodesk.Revit.DB
# Enable DocumentManager and TransactionManager
# Enable ICollection List Translate
clr.AddReference("System")
import System.Collections.Generic
app = uiapp.Application
class WarnSwallow(IFailuresPreprocessor):
	def PreprocessFailures(self, failuresAccessor):
		failuresAccessor.DeleteAllWarnings()
		return FailureProcessingResult.Continue
dataEnteringNode = IN
# Use UnwrapElement(IN[0]) When Translating From Dynamo to Revit
points = UnwrapElement(IN[0])
topo = UnwrapElement(IN[1])
minp = UnwrapElement(IN[2])
maxp = UnwrapElement(IN[3])
range = IN[4]
goodpts = UnwrapElement(IN[5])
if range > 0:
	count = 0
	bboxes = []
	for each in minp:
		bboxes.append(dg.BoundingBox.ByCorners(each, maxp[count]))
		count = count + 1
	allpts = topo.GetPoints()
	convpts = []
	for each in allpts:
		convpts.append(each.ToPoint())
	todelpts = []
	for eachbox in bboxes:
		for e in convpts:
			if dg.BoundingBox.Contains(eachbox,e):
				todelpts.append(e)
	uniquetodelpts = set(todelpts)
	todelpts = list(uniquetodelpts)
	todelxyz = []
	for e in todelpts:
		todelxyz.append(e.ToXyz())
	#Disposing Stuff
	for e in convpts:
		e.Dispose()
xyzconvgood = []
for each in goodpts:
	try:
		xyzconvgood.append(each.ToXyz())
	except:
		pass
failproc = WarnSwallow()
ilistofidsgood = List[Autodesk.Revit.DB.XYZ](xyzconvgood)
if range > 0:
	if len(todelxyz) > 0:
		ilistofids = List[Autodesk.Revit.DB.XYZ](todelxyz)
editsession = Architecture.TopographyEditScope(doc,"Topo K-Align")
editsessioncl = Architecture.TopographyEditScope(doc,"Topo Clean Up")
if range > 0:
	try:
			Revit.Transaction.Transaction.End(doc)
			editsessioncl.Start(topo.Id)
			topo.DeletePoints(ilistofids)
			TransactionManager.Instance.ForceCloseTransaction()
			editsessioncl.Commit(failproc)
	except:
		pass
	editsession.Start(topo.Id)
	topo.AddPoints(ilistofidsgood)
	editsession.Commit(failproc)
OUT = topo
