Intersection.dyn (15.0 KB)
Hello Currently I have this script in which I am trying to extend the top offset of the columns to intersect the generic model , The thing is that this generic model have a slope and as you can see in the figure all of the columns are assigned the same top offset . What am I missing here what should I do or add which nodes so that the intersection works perfectly ?
Hello @ahmadkhalaf7892, currently you are not really checking if you have any kind of intersection, that’s why you are failing to get intersection geometry and you should try to do that. I did a similar script a while ago that could give you inspiration for your future endeavours
ElementIntersect.dyn (24.7 KB)
P.S in order for Element.Location node to work you need to change the column style to -Slanted - End Point Driven, then you will be able to get a column generating curve that can be used later for intersecting geometry recovery.
you can change it back after you are done
Also, currently. the script will work if your columns are already clashing, otherwise, just extend the curve
Hi Kristaps
thanks a lot I will check it tommorow and ask right not its after midnight here . But Again I really appreciate the help seems like the nodes that I was missing here
yeah give it a go, you were on the right path, just keep on trying and you’ll get there! Good luck!
